Help with "masks"
Snowfun
Hi,
I'm new to all this so apologies if this is a trivial question!
I'm looking to create a shot with time-lapse sky/clouds against a normal speed foreground. I can achieve a reasonably horizontal and "simple" horizon - but it isn't a "straight line". The "foreground" (normal speed) shots would be tripod based. There are then two alternatives:
1. foreground action taking place under the horizon (i.e. not impinging on the sky or time-lapse space)
2. foreground action takes place above the horizon.
I assume that I need a mask to achieve this? But my question is what is the best tool for this? I use FCX as an editor but have failed dismally to get to grips with Motion.
Any advice much appreciated.
Tim
Masks work very good in After Effects.
There are lots of tutorials of masking, it´s not dificult.
https://helpx.adobe.com/after-effects/using/creating-shapes-masks.html
https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.html
In the composition, place down the "under the horizon" file 1 and up the "above the horizon" file 2.
Mask the file 2 with the pencil or rectangular tool the from the "simple horizon" to the end of the frame (the part of the video that you don´t want in)
And in the mask menu, select Substract (You see Normal, Add, Substract, etc).
You will see now the file 1 frame and file 2 frame, one above the other.
Here you can see how: https://www.youtube.com/watch?v=OzAkb7Cw0uM
(Sorry for my english.)
