amsh89es335 Posted September 22, 2015 Share Posted September 22, 2015 I am thinking about getting the Video Devices Pix-E5 or the Pix-E5H to use with the A7R ii. Will there be any benefit paying more for the Prores 4444 XQ with the A7R ii or FS7. Link to comment Share on other sites More sharing options...
Emanuel Posted September 22, 2015 Share Posted September 22, 2015 Not 4K, only 1080p. Link to comment Share on other sites More sharing options...
John D Posted September 23, 2015 Share Posted September 23, 2015 I'm pretty sure it depends on the source signal. My understanding (albeit limited) is that you don't get more color depth out of recording 12 bit 4:4:4 if the incoming signal is 8 bit 4:2:0 (a7rii), though apparently it can help with flexibility in grading later on. Not sure it's worth it in that case alone. But if you're shooting consistently with an FS7 then it would absolutely be worth it as you can record full 12 bit 4:4:4. Regardless, I can confirm that both recorders are definitely 4K. Take all of this with a grain (or six) of salt as I'm definitely no expert. Link to comment Share on other sites More sharing options...
Don Kotlos Posted September 23, 2015 Share Posted September 23, 2015 On 9/22/2015 at 5:40 AM, amsh89es335 said: I am thinking about getting the Video Devices Pix-E5 or the Pix-E5H to use with the A7R ii. Will there be any benefit paying more for the Prores 4444 XQ with the A7R ii or FS7. All you need is the Pix-E5H (not even the pix-e5 since you don't need sdi). You will not see any difference with 4:4:4. It will only cost you more drive space. Now they will be supporting LUTs too so that is going to be very useful since slog2 makes exposure & WB impossible. Link to comment Share on other sites More sharing options...
Emanuel Posted September 23, 2015 Share Posted September 23, 2015 On 9/23/2015 at 1:26 AM, John D said: I'm pretty sure it depends on the source signal. My understanding (albeit limited) is that you don't get more color depth out of recording 12 bit 4:4:4 if the incoming signal is 8 bit 4:2:0 (a7rii), though apparently it can help with flexibility in grading later on. Not sure it's worth it in that case alone. But if you're shooting consistently with an FS7 then it would absolutely be worth it as you can record full 12 bit 4:4:4. Regardless, I can confirm that both recorders are definitely 4K. Take all of this with a grain (or six) of salt as I'm definitely no expert. Both recorders are 4K. The recording modes are different though. You can record whatever you want, 8-bit output will always offer 8-bit signal to record, whatever mode you have going with the external recorder. You'll only add empty data. That is, nothing will change for your grading. Link to comment Share on other sites More sharing options...
Don Kotlos Posted September 23, 2015 Share Posted September 23, 2015 On 9/23/2015 at 1:48 AM, Emanuel said: Both recorders are 4K. The recording modes are different though. You can record whatever you want, 8-bit output will always offer 8-bit signal to record, whatever mode you have going with the external recorder. You'll only add empty data. That is, nothing will change for your grading.In some cases working in a larger space (at least in bit depth) has some benefits for some effects. Andrew had some examples with noise a while back. 10bit 4:2:2 prores hq should be more than enough extra space. Also now I realized that the 4:4:4 XQ signal is recorded only through SDI that is not available with A7rii. So that makes OPs choice easier... Link to comment Share on other sites More sharing options...
Emanuel Posted September 23, 2015 Share Posted September 23, 2015 On 9/23/2015 at 2:10 AM, Don Kotlos said: In some cases working in a larger space (at least in bit depth) has some benefits for some effects. Andrew had some examples with noise a while back. 10bit 4:2:2 prores hq should be more than enough extra space. I would need to see it to believe it... ;-) On 9/23/2015 at 2:10 AM, Don Kotlos said: Also now I realized that the 4:4:4 XQ signal is recorded only through SDI that is not available with A7rii. So that makes OPs choice easier...Right :-) Without mention... SDI there, it is 3G-SDI up to 1080p60. Link to comment Share on other sites More sharing options...
