EOSHD Intra-esting (in_f)
Francisco Rios
I'm shooting with the intra frame patch from Andrew. It works at 88Mbit AVCHD Intra. I use sandisk card class 10 ,30 mb/s.
The patch is fantastic and works great with the card. No problem at all. I can record 12 minutes without stop.
16 gb cards means 24 minutes for recording.
The blacks of the image are amazing.
My question is about post. I use premiere pro CS 5.0.
I made two diferente sequence for test and edit the footage:
1. avchd 1080p24
2.AVC-Intra 100p24
I can edit with boths, but I think works better with the avc-intra.
Can anyone share your experience with Premiere and this patch?
I want to know the right way to set the sequence in premiere for this patch.
Thanks.
It will work better with AVC-Intra, and an i-frame recording is less demanding on CPU speed so you will get a smoother workflow with it as well. Nice to see the blacks hold up in your footage... My Mac has lost mine.
